TwinTurbo.NET: Nissan 300ZX forum - Yes, that screw should turn easily so long as it's the right
FrozTTy
on August 13, 2021 at 8:09 AM
Re: Look at all fuel hoses for leaks, that's usually why you'll
posted by Gagej
on August 12, 2021 at 09:57 PM
screw!
Also - make sure you have the correct NGK spark plugs. Don't use anything else! The Z is a particular son of a gun
Beginner Drift build
Gagej
22:42:47 07/30/21
You got some reading to do
Cjw3
08:08:14 07/31/21
Re: You got some reading to do
Gagej
13:56:42 07/31/21
Engine Out is better
Cjw3
19:25:22 07/31/21
Is it a 2+2? The longer wheelbase will make it a better
MixManMash
17:40:16 08/01/21
Re: Is it a 2+2? The longer wheelbase will make it a better
Gagej
19:43:23 08/01/21
Yes it is.
Cjw3
06:51:44 08/02/21
Engine compartment is the same between coupe and 2+2
ZXoltan
16:01:09 08/02/21
No, the power switched mod and PRVR delete are two separate
FrozTTy
15:37:58 08/02/21
Rough Idle Help
Gagej
14:50:43 08/02/21
Power Balance Test
FrozTTy
15:27:25 08/02/21
Re: Power Balance Test
Gagej
18:49:16 08/02/21
Update
Gagej
15:42:55 08/04/21
Injector Ohm Test
Gagej
22:48:00 08/04/21
Remove coil pack connector from injector
FrozTTy
11:11:38 08/05/21
Re: Remove coil pack connector from injector
Gagej
18:25:53 08/05/21
FrozTTy
10:41:09 08/06/21
Gagej
21:57:20 08/12/21
Yes, that screw should turn easily so long as it's the right -
FrozTTy
08:09:17 08/13/21
Re: Yes, that screw should turn easily so long as it's the right
Gagej
11:39:24 08/13/21
Update
Gagej
16:04:18 08/04/21
